Hub M3 security in HA
Is there a reliable way to see Home/Night/Away settings from my M3 hub in HA? Thanks!
Hi @starlitter, if you connect your M3 via HomeKit, you’ll also get the alarm panel in Home Assistant. The only thing you need to do is disable the child devices in HomeKit, because they will be imported as well. Of course, you can continue using everything through Matter (if you have child device).
This is the only way to get the alarm system from the Aqara Home app into Home Assistant. And the great thing is that they are fully synchronized. So, if you arm/disarm it from Home Assistant, you’ll see the exact same status in Aqara Home, and vice versa.
This is also my setup, and I can confirm that it works 100%.
I’ve been using this system for months now without any issues.
You rock! Very helpful, and thorough.
Thank you. I hope that helps you.
It works like a charm! I just did this today because I had to work up the confidence to do anything with my main hub. But it is SOO nice to have the security stuff in HA. Thanks again!
Thanks and enjoy it in Home Assistant. I set it up with geofencing and it works great.
