HUB placement - density optimization
Hi. Is there a tool to be able to see hub placement optimization to optimize sensor communication efficiency? I have a big area to cover, and some kind of walk though heat map would be great. I have this for my wifi setup with unifi.
Hi @guylopes71 , there is currently no custom Zigbee network map, maybe it will appear in the future.
If you have a large area, you need to use Zigbee signal repeater devices for better signal coverage over large areas.
Aqara devices powered by a 220v network (neutral is required) are repeaters (relays with neutral, switches with neutral, motors for 220v curtains, sockets, light bulbs, etc.)
Thanks you!
Díky, počkám
Dear, is there any progress for having a possibility to have the network map of the zigbee network, it is really usefull when trying to understand why some connections are lost and where extra repeayor should be placed to avoid such issue?
