I’m wondering how to implement new map with hubs, would you suggest a dedicated hub such as M200 for several sensors o a g5 pro camera is sufficient? I’m also considering that g5 pro would be linked to electricity while the m200 could be linked with an ups
@h49qvxzx9t Hi there! Great question. It sounds like you are planning a robust smart home setup with some specific power considerations.
Both the Aqara Hub M200 and the Smart Camera G5 Pro can function as hubs, but they have different strengths depending on your needs.
The Smart Camera G5 Pro actually doubles as a powerful hub. It comes with built-in Zigbee hub, Matter Controller, and Thread Border Router functionalities, allowing it to expand your smart home system significantly. It is also designed to be an outdoor camera with high-quality image and AI recognition capabilities. However, please note that the G5 Pro requires a constant power source (either via USB-C adapter or PoE) and does not support battery operation or direct UPS connection in the way a dedicated hub might be designed for backup.
On the other hand, the Aqara Hub M200 is a dedicated hub that simplifies setup by delivering both power and data through a single cable if you use its PoE port. It features an upgraded Automations 2.0 engine that runs locally, which is great for reliability even if the internet goes down. Since you mentioned linking the M200 to a UPS, this is a valid strategy to ensure your automation rules and hub connectivity remain stable during power outages.
If your primary goal is to manage sensors and run local automations reliably during power fluctuations, the Hub M200 might be the more suitable choice for the core hub role, especially given your UPS plan. The G5 Pro is excellent if you also need high-end surveillance and AI features, but it needs constant power. Many users find that using the M200 as the central automation hub while using G5 Pro cameras for monitoring works very well together.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.[“content_id”:7"]
Happy building! Let us know how your setup goes.
