Currently using the M2 and M100 hubs but is there a benefit to changing to the newer hub?
@jonathan_dowson Hey there! Great question — upgrading hubs really depends on what you’re looking to get out of your setup.
The Hub M100 you’re already using is actually one of Aqara’s newer offerings with some solid perks: it acts as a Matter Controller and Thread Border Router, supports local automations for Zigbee and Thread devices, and runs on Wi-Fi 6 with WPA3 for better security and performance in busy networks. It’s also super flexible with its USB-A power, so you can plug it pretty much anywhere.
That said, if you’re considering the Hub M3, the main upgrade would be Ark-Tech 2.0 — that’s Aqara’s distributed disaster recovery system. The M3 offers autonomous redundant backup where multiple M3 hubs can back each other up across floors, and if one goes down, another takes over automatically. It also has proxy hub self-healing, where Zigbee devices can step in to keep basic automations running if the main hub fails.
Quick take: If your current M2 + M100 combo is stable and you’re happy with local execution and Matter bridging, you might not need to rush. But if you want enterprise-grade reliability, multi-hub redundancy, and live in a larger home where hub failures would be disruptive, the M3 is a meaningful step up.
What pain points are you hoping to solve? That might help narrow it down
Depends on your needs! If you need something more advanced… take M3
