Hello fellow smart home enthusiasts! I’ve been diving into the world of Home Assistant and Hue integration, and I wanted to share my journey and solution to a common issue I encountered.
The Problem: My Hue Bridge’s IP address changed due to my network’s DHCP settings, causing my temperature sensors to stop updating. I realized I needed a way to monitor the Hue Bridge’s online status directly on my dashboard.
The Solution: After some research, I discovered that configuring a Thing/Model to display the Hue Bridge’s online status is not only possible but also quite straightforward. Here’s how I did it:
- Identify the Hue Bridge Entity: Locate your Hue Bridge in the Home Assistant entity list. It’s usually named something like
hue_bridge.<your_bridge_id>. - Create a Custom Card: I used a custom card to display the online status. Here’s a snippet of the code I used:
yaml
- type: ‘custom:hue-bridge-status’
entity: hue_bridge.<your_bridge_id>
name: ‘Hue Bridge Status’
show_name: true
show_online: true
show_reachable: true
show_firmware: true
Styling with CSS: To make it visually appealing, I added some CSS to change the background color based on the bridge’s status:
css
.hue-bridge-status {
background-color: #f0f0f0;
padding: 10px;
border-radius: 5px;
.hue-bridge-status.online {
background-color: #4CAF50;
color: white;
.hue-bridge-status.offline {
background-color: #f44336;
color: white;
Lock Down the IP Address: To prevent future IP changes, I locked the Hue Bridge’s IP address in my router’s DHCP settings. This ensures consistent communication between my Hue Bridge and Home Assistant.
Conclusion: Monitoring the Hue Bridge’s online status has been a game-changer for me. It provides peace of mind and helps troubleshoot connectivity issues before they escalate. I hope this guide helps others facing similar challenges!
Happy smart home hacking! ![]()
