Hue Light Color Randomizer: A Fun Experiment and Solution
Hey everyone! I wanted to share a fun experiment I did with my Hue lights and how I solved a little issue that came up. It all started when I decided to create a smart app that would randomly change the color of my Hue bulbs whenever I turned on a specific switch. The idea was to add a bit of excitement and randomness to my home lighting setup.
I wrote a simple app that would select a random hue from a predefined list and apply it to all connected Hue bulbs. The app seemed to work perfectly in the simulator, cycling through different colors without any issues. But as soon as I deployed it to my actual setup, things took a unexpected turn.
The bulbs would only turn on in red, even if red wasn’t in the random list I had set up. It was pretty frustrating! I scratched my head for a while, checking logs and going through the code line by line. After some trial and error, I realized the issue was with how the saturation and brightness levels were being set. The app was inadvertently overriding these settings, causing the bulbs to default to red.
To fix this, I adjusted the code to ensure that saturation and brightness levels were maintained consistently. I also added some logging to help troubleshoot any future issues. Now, the app works like a charm, cycling through a vibrant spectrum of colors whenever I toggle the switch.
This little experiment taught me the importance of thorough testing and the value of community support. If you’re looking to try something similar, I’d recommend starting with a small setup and gradually scaling up. It’s also a great way to get creative with your smart home setup!
If anyone else has tried something like this or has tips to share, I’d love to hear about your experiences. Happy coding and happy lighting! :rocket:
