I recently faced a challenge with setting up a humidity change trigger in my smart home system. The goal was to automatically turn on the bathroom fan when there’s a 10% rise in humidity, regardless of the current level. After some research and experimentation, I found a workaround that involves using a rule with a threshold comparison. Here’s how I implemented it:
- Setup: I used a Zooz 4-in-1 sensor to monitor humidity levels and a Z-Wave wall switch to control the fan.
- Rule Creation: Instead of relying solely on a specific humidity value, I set up a rule that triggers when the humidity increases by 10% from the previous reading. This approach accounts for seasonal variations in humidity levels.
- Testing: I tested the system during both high and low humidity periods to ensure reliability. It worked seamlessly, adjusting to the changing conditions without false triggers.
Experience: This solution has been a game-changer for maintaining a comfortable environment in my home. It’s especially useful during the summer months when humidity levels can fluctuate rapidly. I’m grateful for the community resources that helped me troubleshoot and refine this setup. If anyone has further questions or improvements, I’d be happy to discuss them!
