Humidity Monitoring and Automation Insights
Hello fellow smart home enthusiasts! I wanted to share my journey with humidity monitoring and how it’s integrated into my smart home setup. It’s been quite an enlightening experience, and I hope you find some tips or ideas here!
My Setup
I have an automated heating system equipped with humidity sensors, though I’ve only recently started leveraging them. The goal is to optimize energy use while maintaining a comfortable indoor environment. I’ve set the acceptable humidity range between 30-70%, with the system taking action only when levels fall outside this range.
The Challenge
Humidity is a tricky beast. It’s not just about the numbers; it’s about how those numbers change with temperature. For instance, during the colder months, steam from cooking can significantly raise humidity levels. Without proper venting, this moisture can condense on surfaces, leading to mold growth—a problem I unfortunately encountered last winter.
My Solution
I’ve implemented a two-pronged approach. First, the system monitors humidity levels and suggests actions through my Grafana dashboard. This could be as simple as opening a window or as involved as purchasing a dehumidifier. Second, the heating system adjusts temperatures to lower relative humidity temporarily, though this is a last resort due to the energy cost.
A Little Story
Last year, I sealed off a room for renovations, only to discover mold growth after two months. It was a wake-up call. Since then, I’ve been diligent about monitoring and acting promptly. A quick clean-up and repainting later, the room is back to being a safe, comfortable space.
Looking for Feedback
I’m curious to hear how others manage humidity in their homes. Do you have a favorite device or method? I’d love to explore more creative solutions or learn about your experiences!
Happy automating! :cloud_with_rain:
