Humidity sensor automation tips and tricks
Hey everyone, I’ve been working on setting up a humidity control system in my bathroom, and I thought I’d share my experiences and some tips that might help others avoid the same pitfalls I encountered.
The Setup:
I have a virtual switch that activates when the humidity in my bathroom reaches a certain threshold—20% higher than another room on the same floor. The idea is that once the humidity drops below 15% over the other room, the virtual switch should turn off. Sounds straightforward, right?
The Challenge:
While the switch turns on perfectly, it never turns off automatically. After hours of troubleshooting and tweaking the rules, I realized the issue wasn’t with the hardware but with how the automation was structured.
What I Learned:
  1. Threshold Sensitivity: The 15% drop-off threshold might be too aggressive. I adjusted it to 10% and saw immediate improvement.
  2. Timing is Everything: I added a delay before the switch turns off to ensure the humidity has stabilized.
  3. Sensor Placement: Moving the sensors to avoid direct airflow from vents or fans made a huge difference.
Final Thoughts:
It’s all about balancing sensitivity and responsiveness. Don’t be afraid to experiment with your thresholds and delays. A well-tuned system can be a game-changer for maintaining a comfortable environment.
If anyone has additional tips or has faced similar issues, I’d love to hear your experiences! :door::droplet:
