I have not been able to successfully pair my shades hub (Powerview Gateway Hunter Douglas, matter enabled) into my Aqara ecosystem
I was able to pair the Powerview Gateway successfully via matter to Apple Home Kit (works great!), but haven’t been able to do so into Aqara App
I tried pairing it directly from the Powerview Gateway hub (getting a matter code from the Powerview App) and also via Apple Home (getting a matter code from Home kit), but none of those worked.
The Aqara app does find the device when I add as a matter accessory. It asks for which of my M3 hubs I want to pair it as a matter controller (I have an M3 hub close by) and asks if I’d like to add the device to my Aqara. After going through the setup it says “Unable to Add Accessory, Home couldn’t connect to this accessory”.
Any ideas on how to solve this? My M3 is in the same room as the Powerview Hub.
@BrooklynHome It sounds like you’re having trouble pairing your Hunter Douglas Powerview Gateway (Matter-enabled) with the Aqara ecosystem, even though it works well with Apple HomeKit. Let’s try some troubleshooting steps based on common Matter device pairing scenarios:
First, ensure your Aqara Home app is updated to the latest version, and the firmware of your M3 hub is also up-to-date. Matter device pairing often relies on both the app and hub firmware being current.
Next, check if your router supports IPv6. Matter devices require IPv6 to connect successfully—you can try turning IPv6 off and back on in your router settings.
Also, verify the Thread network status of your M3 hub. In the Aqara Home app, check the hub’s network details to ensure a Thread network is successfully generated. If the Thread network is blank, you won’t be able to add Matter devices. If you recently created a new Thread network, existing Matter devices might need to be reset and reconnected.
Since you have an M3 hub, make sure it’s the only Matter controller in your Aqara Home setup or that all controllers are on the same local network.
If these steps don’t resolve the issue, you can contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, “Please
click here” to create a ticket.
