I recently discovered a fantastic integration that has been a game-changer for my smart home setup! After years of frustration with the iDevices outlet, I finally found a way to utilize its power monitoring features in a meaningful way. Let me walk you through how I made this happen and how it has transformed my automation capabilities.
First, a bit of background: I’ve had an iDevices outlet for years, but it always felt underutilized. The power measurements were only visible in the iDevices app, which meant I couldn’t incorporate them into my HomeKit automations. That all changed when Controller for HomeKit released a significant update. I was thrilled to find out that the outlet’s power readings were now accessible within the app!
However, there was a catch. HomeKit automation has some limitations, particularly when it comes to periodic triggers. This is where Hubitat came to the rescue. By combining Controller for HomeKit with Hubitat, I was able to overcome these limitations and create a seamless automation workflow. Here’s how I did it:
- Join the iDevices outlet to HomeKit: This was the first step to ensure compatibility with other HomeKit devices and services.
- Install the necessary components: I set up a Hubitat Elevation hub alongside the HomeKit Integration and Controller for HomeKit Pro. This combination allowed me to bridge the gap between HomeKit and Hubitat’s powerful automation capabilities.
- Create a virtual switch on Hubitat: This switch acts as a trigger for my automations. I configured it to turn on periodically using a Rule Machine (RM) rule.
- Set up the automation in Controller for HomeKit: Using the power readings from the iDevices outlet, I created an automation that triggers based on specific wattage thresholds. This automation is then executed in the Apple Home app.
The result? I can now automate actions based on real-time power consumption data from my iDevices outlet. For example, if a device consumes more power than expected, I can trigger a scene or notification to address the issue. This integration has opened up a world of possibilities for optimizing energy usage in my home.
If you’re looking to enhance your smart home setup with power monitoring and automation, I highly recommend exploring this integration. It’s a bit of a puzzle to piece together, but the payoff is well worth the effort. Happy automating! ![]()
