Improved Z-Wave Network Reliability with Aeotec Range Extenders
I wanted to share my recent experience with improving my Z-Wave network reliability after struggling with intermittent connectivity issues with my Schlage locks (BE469 and FE599). After some research and guidance from Hubitat support, I decided to add three Aeotec Range Extender 6 devices to my network. The results have been nothing short of fantastic!
Initially, I was placing the range extenders close to the devices, but following the advice I received, I positioned them strategically around my hub. One is just 6 inches away from the hub, another about 4 feet away, and the third 20 feet away in the opposite direction. This setup covers my entire 1800 sq ft townhouse effectively.
Since installing these range extenders and rebuilding my Z-Wave network, I haven’t experienced any dropped connections with my locks. The biggest improvement is the reliability of adding and deleting lock codes through Hubitat—something that was hit or miss before. Here’s a quick breakdown of the changes I noticed:
BE469 Lock:- Manual lock/unlock operations now consistently trigger device state changes for automations.- Lock codes work reliably in automations.
FE599 Lock:- While manual lock/unlock operations are detected, they require a device refresh to update the state in Hubitat. Automations using lock codes still need attention, but the core functionality is there.
I’ve also noticed a general improvement in the stability of my entire Z-Wave network. Devices like my Aeotec leak sensor and motion sensors are now more responsive and reliable.
**Tips for Others Considering Range Extenders:**1. Positioning Matters: Place extenders closer to the hub rather than the devices. This creates a stronger network backbone.2. Rebuild the Network: After adding new devices, always rebuild the Z-Wave network to optimize routing.3. Monitor Network Health: Regularly check the Z-Wave network map in Hubitat to ensure all devices are communicating effectively.
A huge thank you to Hubitat support for the guidance! If you’re dealing with Z-Wave reliability issues, I highly recommend exploring range extenders as a solution. It’s been a game-changer for my setup!
