Hey everyone, I’ve been diving into optimizing my OpenHAB setup, and I came across a performance issue with charts that I wanted to share my experience with. Hopefully, this can help others who might be facing similar challenges!
So, the problem I encountered was that certain charts were taking way too long to load. Specifically, I noticed that a page with multiple charts would take around 8-10 seconds to render, which was quite frustrating. I started by reviewing my configuration and realized that the issue might be related to how the charts were set up. I had several time series charts on a single page, each with different data points and configurations.
To tackle this, I decided to break down the problem. First, I looked into the chart configuration itself. I found that having too many series on a single chart can significantly slow down the rendering process. To mitigate this, I considered splitting the charts into separate grids, which helped distribute the load more evenly. Additionally, I reviewed the dataZoom and grid configurations to ensure they weren’t causing unnecessary delays.
Another thing I noticed was the use of multiple markPoint and markLine configurations. While these are useful for highlighting specific data points, they can add to the complexity and loading time. I simplified some of these configurations and found that the charts loaded much faster as a result.
I also explored the possibility of optimizing the data retrieval process. Since I was using the rrd4j persistence service, I made sure that the data was being fetched efficiently. This involved tweaking the period settings and ensuring that the data wasn’t being over-sampled.
After making these adjustments, I saw a noticeable improvement in the chart loading times. The page now loads in under 2 seconds, which is a huge improvement. It was a bit of a trial and error process, but breaking down the problem and tackling each component step by step really helped.
If anyone else is experiencing similar issues, I’d recommend starting by reviewing the chart configurations and looking for areas where you can simplify or optimize. Also, ensuring that your persistence service is properly configured can make a big difference. Happy troubleshooting! ![]()
