Improving Night Vision on Wyze Cam 3: My Experience and Solution
I recently encountered an issue with my Wyze Cam 3’s night vision functionality, and I wanted to share my experience and the solution I found. Hopefully, this can help others facing similar problems.
The Problem:
My Wyze Cam 3, set up inside my house pointing through a window, started experiencing poor night vision around 11:00 PM. The camera would display a glare from the window, and adjusting the auto-night vision settings didn’t resolve the issue. This persisted until sunrise, which was quite frustrating.
What I Tried:
I experimented with different auto-night vision settings, but none seemed to make a difference. The glare remained, and the video quality was significantly reduced during the night. I even attached a short video showing the change in vision quality, but the issue remained unresolved.
The Solution:
After some research and trial and error, I discovered that the placement of the camera was contributing to the problem. The glare from the window was causing the night vision to struggle. To mitigate this, I adjusted the camera’s angle slightly to reduce the direct glare. Additionally, I found that enabling the ‘Anti-Glare’ feature in the Wyze app helped improve the night vision quality.
Final Thoughts:
While the issue was initially disheartening, troubleshooting and finding a solution gave me a sense of accomplishment. It’s a good reminder that sometimes adjusting the setup or exploring additional features can resolve unexpected issues. I hope this helps anyone else dealing with similar night vision problems on their Wyze Cam 3!
Happy smart home tinkering! :blush:
