Improving Z-Wave Network Reliability: My Journey and Tips
Hey everyone, I wanted to share my experience with improving the reliability of my Z-Wave network. It’s been a bit of a rollercoaster, but I’ve learned a lot along the way!
The Issue:
For the past few months, I’ve noticed that my Z-Wave devices were becoming less reliable. Commands to toggle switches or adjust radiator settings were failing more frequently. At first, I thought it might be a hardware issue, but after checking the devices and ensuring they were within range, I realized the problem was deeper.
The Investigation:
I started by reviewing the network health in the Z-Wave JS UI. The graph showed some nodes were disconnected, even though they were functioning normally. I tried a network heal, but it didn’t resolve the issue. I also considered the possibility of interference, so I moved some devices to different locations.
The Solution:
After some research, I discovered that adding more powered nodes to act as repeaters significantly improved the network’s reliability. I added a couple of powered switches, and the failed command rate dropped dramatically. It was a simple fix, but it made a huge difference!
Tips for Others:
  • Regularly check your network health in the Z-Wave JS UI.
  • Consider adding powered repeaters if you notice frequent communication issues.
  • Experiment with device placement to minimize interference.
Final Thoughts:
It’s amazing how a few adjustments can make such a big impact. I’m now much more confident in my Z-Wave setup, and it’s running smoother than ever. If anyone else is struggling with network reliability, I hope this helps!
Best regards,
