Improving Zigbee Network Performance with Source Routing
Hey everyone, I wanted to share a really cool discovery I made about optimizing my Zigbee network. I’ve been dealing with occasional delays and instability, especially as my network has grown. After some research, I stumbled upon the concept of Source Routing versus Table Routing in Zigbee. Let me break it down for you!
Table Routing is the default method where each device independently figures out the best path for messages. While it works, it can lead to a lot of network chatter as devices constantly search for new routes, especially in larger setups. This can cause delays and even dropped packets.
Source Routing, on the other hand, takes a more centralized approach. The coordinator maps out the optimal path for each message, reducing the overall network load and improving efficiency. I’ve been using this method for a few weeks now, and the difference is night and day!
Here’s how I set it up:
  1. Opened my configuration.yaml file.
  2. Added the following line under the Zigbee section:
    zigpy_config:
    source_routing: true
  3. Restarted my system to apply the changes.
After about 10 minutes, I noticed a significant improvement. My automation commands are responding much faster, and the network feels more stable overall. If you’re experiencing similar issues, I highly recommend giving Source Routing a try!
Would love to hear if others have noticed the same benefits or if there are any potential downsides I should be aware of. Happy tweaking! :rocket:
