Are there any suggestions for a CL3 rated USB C cable to use in-wall with the FP2 presence sensor? It would be nice if one was supplied with the FP2! I don’t mind running an uncertified cable inside the wall temporarily to set up the sensor, but I’d like everything to be up to code when I’m done with setup. 15 feet/5 meters should be plenty.
Theres always ethernet. You could have poe injection on one end, and usb c to poe on the other. Ethernet behind the drywall as your power transport.
You only need CL2
In wall rated. If CL2 is available I’ll use it!
I’d like to get away with no adapters. Too bad the sensor isn’t POE!
