Inconsistent connections in multistory home
What do you do about inconsistent connections?
@mrosen7 Hey there! Dealing with spotty connections across multiple floors is a pretty common smart home headache. Here are a few things that tend to help:
For your hub/gateway placement
  • Keep it central and elevated if possible—WiFi and Zigbee signals spread outward and downward better than trying to punch through floors from below.
  • If you’ve got a dual-band router, split the frequencies and disable WiFi 7 compatibility mode to see if stability improves.
  • Make sure the hub is within 1-2 meters of the router with minimal obstructions between them.
For adding or reconnecting devices
  • When pairing new devices, bring them close to the hub first—you can always relocate them after they’re connected.
  • If you’re working with Matter devices (Hub M3/M100), know that creating a new Thread network will drop all existing Matter connections, so you’ll need to reconnect them afterward.
General network hygiene
  • Stick to 2.4GHz for most Aqara devices, and avoid dual-band-integrated networks with spaces or special characters in the SSID.
  • If one floor is particularly stubborn, a strategically placed range extender or a second hub on that level can work wonders.
If you’ve tried the basics and still get frequent dropouts—especially if your gateway loses device connections weekly and needs constant refreshes—it might be worth checking whether your router’s AP isolation or connection watcher features are interfering, or if a factory router reset is in order.
Still struggling after all that? You seem to be experiencing an issue with inconsistent multi-floor smart home connectivity. You can contact customer support for assistance.
