Incorrect Battery Status in Consumable Overview
Dear Aqara Support Team,
I noticed an issue in the Consumable Overview tab of the Aqara app.
The battery status of my devices is shown as 100% or sufficient, but when I open each individual device, the actual battery status is different. Some devices have already run out of battery, while others show only “Medium” battery level.
This means the battery information displayed in the Consumable Overview is not accurate and does not match the actual status of the individual devices.
If the battery status shown in Consumable Overview is incorrect, how can users know when they need to replace the batteries in time? This could cause devices to stop working unexpectedly because users are relying on the information provided by the app.
Please check whether this is a bug in the app, a synchronization issue, or an issue with how battery status is being reported. I would appreciate it if you could check my account/device logs and provide a proper explanation and solution.
Thank you.
Hello, thanks for the information, I have forwarded your comments to the Aqara team.
Personally I’ve always got either incorrect percentage or almost no info (“sufficient battery”) in “Consumables overview”. It is, however, useful for checking the battery type.
If you hold the accessory tile in Apple Home and tap “settings” then you will get an exact percentage
