Does anyone know how to control an infrared-controlled device placed in a room far from the main Aqara hub?
The infrared controller requires a clear line of sight. You can use mirrors. But I’d recommend buying an M3 hub; it works very well for me.
Hi. You won’t believe it, but I used the mirror in the hallway to control the M3, the TV in the living room😂
Hello @archipietro
It is better to use simple logic: one room = one hub with IR
I was just wondering if there is a small device that can be located in a room dedicate to control other infrared devices but controlled via Wi-Fi buy an Aqara hub.
Maybe other brands do it?
Hello, only M3 and M2 gateways support this.
and the G3 gateway camera, in other regions also the P3 companion, and the presented M200 hub
Thank you for adding information.
