Install Aqara PoE Cameras
I’m looking on getting the new Aqara cameras and running Ethernet for PoE.
Interested to hear people’s feedback and reliability when it comes the cameras. Anything I should look out for?
TIA!
@drewburnett21 Hey there! :wave: It’s great to see you diving into the world of Aqara PoE cameras. PoE is definitely a robust choice for stability, especially if you’re running cables anyway.
Based on what we know about the setup, here are a couple of things to keep in mind:
For the Smart Camera G5 Pro (PoE Version), the setup is quite straightforward. You just need to connect the camera to your network using an Ethernet cable and power it on. Once powered, the status indicator should flash yellow, and the Aqara Home App should automatically discover the device for you to bind it.
However, if you are considering the Aqara Doorbell Camera G400 with PoE, there is a specific distance consideration. If you are installing it on a yard wall or fence, especially where Wi-Fi signals from your router might be weak, the PoE method is highly recommended. Just remember to keep the distance between the doorbell and the chime within 30 meters, assuming they are separated by only one wall with a thickness of ≤24cm.
Generally, for any Aqara device, ensuring a stable connection and avoiding metal obstacles is key to reliability.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Have you decided on a specific model yet? I’d love to hear which one catches your eye!
