I’ve been on a journey to integrate my ETEKCITY ZAP 3F remote outlet switches into my SmartThings ecosystem, and I’m thrilled to share my experience with you! ![]()
The Challenge:
I came across a few posts where users were struggling to connect their 433MHz RF devices with SmartThings. My outlets were no exception—they worked perfectly on their own, but I wanted seamless integration with my smart home setup. Little did I know, this would turn into a fascinating DIY project!
The Solution:
After some research, I stumbled upon the ST_Anything library by DanielOgorchock. It was exactly what I needed! This library, combined with an Arduino and ThingShield, allows you to control RF devices directly from SmartThings. Here’s how I made it happen:
Hardware Setup:
- I wired my Arduino Uno to the ThingShield and attached a 433MHz transmitter. I also added an antenna to improve range—this was crucial for reliable performance!
Code Integration:
I loaded the ST_Anything_RCSwitch sketch onto my Arduino. This involved modifying the code to match the RF codes of my ETEKCITY outlets. The process was straightforward once I understood the parameters:
//Executors
static st::EX_RCSwitch executor1(F(“rcswitch1”), PIN_RCSWITCH, 5526835, 24, 5526844, 24, 174, 1, 15, LOW);Each argument corresponds to the device’s unique codes and settings.
SmartThings Configuration:
- I installed the ST_Anything_RCSwitch Device Type in the SmartThings IDE. Then, I created three Virtual Switches using the provided VirtualSwitch.device.groovy file. Finally, I tied everything together with the ST_Anything_RCSwitch_Multiplexer SmartApp. This setup allows independent control of each outlet through traditional SmartThings apps or voice commands.
Testing and Troubleshooting:
- Initially, I faced some hiccups with the Arduino IDE version. I had to switch to v1.6.5 temporarily until v1.6.7 was released. Once that was sorted, everything ran smoothly!
- I also discovered that the antenna made a significant difference in range. Without it, the signal was spotty, but with it, I could control my outlets from anywhere in the house.
The Outcome:
I now have full control over my ETEKCITY outlets through SmartThings! It’s incredibly satisfying to see everything working seamlessly. This project not only enhanced my smart home setup but also gave me a deeper understanding of how different components interact.
Tips for Others:
- Start Small: Begin with one device to ensure everything works before scaling up.
- Antenna is Key: Don’t skip adding an antenna—it’s worth the effort!
- Code Customization: Take your time to understand the code and how to adjust it for your specific devices.
If you’re looking to integrate RF devices into your SmartThings setup, I highly recommend exploring the ST_Anything library. It’s a fantastic way to expand your smart home capabilities without breaking the bank! ![]()
Happy tinkering! ![]()
