Integrating a Waterproof Fingerprint/RFID Device with Homey
I recently decided to upgrade my home security system by integrating a waterproof fingerprint and RFID device with my Homey setup. After some research, I found a reliable device on AliExpress that met my needs. Here’s how I made it work:
Device Overview
The device I chose is a standalone keypad with fingerprint and RFID capabilities. It’s designed to be weatherproof, making it perfect for my outdoor setup. The device connects to Homey via ESP, allowing seamless integration into my smart home ecosystem.
Integration Process
  1. Purchase and Setup: I ordered the device from AliExpress and waited for it to arrive. Once it did, I spent some time familiarizing myself with its features and settings.
  2. Connecting to Homey: The device uses the Tuya app for initial setup, which was straightforward. I then used an ESP module to connect it to my Homey hub. This involved some basic wiring and configuration in the Homey app.
  3. Customization: I programmed the device to recognize multiple fingerprints and RFID tags, allowing access for family members and guests. I also set up notifications in Homey to alert me whenever someone uses the device.
Challenges and Solutions
  • Initial Configuration: The device required some tweaking to ensure it communicated properly with Homey. I had to adjust the ESP settings and test the connection multiple times.
  • Weatherproofing: While the device is waterproof, I made sure to install it in a shaded area to protect it from direct sunlight and extreme temperatures.
Tips for Others
If you’re considering a similar setup, here are my recommendations:
  • Research Thoroughly: Look for devices with good reviews and check compatibility with your Homey setup.
  • Plan Your Installation: Decide on the best location for your device to ensure optimal performance.
  • Test Regularly: After installation, test the device frequently to catch any issues early.
Conclusion
Integrating this fingerprint/RFID device with Homey has significantly enhanced my home security. It’s user-friendly, reliable, and has added a new layer of convenience to my smart home setup. I’m excited to see how this integration evolves in the future!
If anyone has questions or needs help with a similar project, feel free to reach out. I’d be happy to share more details or troubleshoot issues!
Hi! Is it possible to receive a DM with your setup?
