I recently discovered an excellent way to integrate the BME680 air quality sensor into my Home Assistant setup. This sensor is fantastic because it includes a gas sensor that provides an indication of air quality—higher resistance means better quality. I wanted to share my setup process in case anyone else is looking to do something similar.
Setup Requirements
- Sonoff Basic flashed with Tasmota (I tested both R1 and R2 versions. R1 seems more reliable as the sensor stayed online longer.)
- BME680 Sensor
- Minimal soldering skills
- Running MQTT Broker
- OpenHAB MQTT Binding and JSONPATH Transformation
Configuration Steps
Flash the Sonoff Device
Use the Tasmota web installer to flash your Sonoff Basic with the Tasmota-sensors firmware. This step is straightforward and ensures your device is ready for sensor integration. -
Connect the BME680 Sensor
Follow the wiring instructions provided in the Tasmota documentation to connect the BME680 to your Sonoff device. This involves soldering, so make sure you’re comfortable with that or have someone experienced help. -
MQTT Settings
Configure your Sonoff device to connect to your MQTT broker. Customize the host and user data according to your setup. This ensures the sensor data is published to the right topics. -
OpenHAB Configuration
Create a MQTT Thing in OpenHAB to bridge the sensor data. Define channels for power, RSSI, temperature, humidity, pressure, and gas readings. Each channel maps to the corresponding data from the BME680 sensor. -
Widget Template
Design a widget to display the sensor data in a user-friendly way. Use conditional formatting to change the background color based on the gas sensor reading, making it easy to interpret the air quality at a glance.
Tips and Tricks
- Firmware Choice: If you experience connectivity issues with R2, consider switching to R1 for better reliability.
- Mounting: Securely mount the sensor in an area where air quality monitoring is critical, like a living room or bedroom.
- Data Visualization: Use OpenHAB’s built-in widgets or third-party integrations to create dashboards that display your sensor data alongside other home automation metrics.
Conclusion
Integrating the BME680 with Home Assistant has been a rewarding experience. It not only enhances my home automation setup but also provides valuable insights into indoor air quality. I’m excited to explore more sensor integrations and continue improving my smart home ecosystem. If you have any questions or tips, feel free to share!
Thanks to the open-source community for making this possible! ![]()
