I’ve been diving into the world of ESPHome and ultrasonic sensors lately, and I thought I’d share my experiences with integrating the AJ-SR04M module. For those who might not be familiar, the AJ-SR04M is a versatile ultrasonic sensor that can operate in multiple modes, each with its own set of requirements and benefits. My goal was to get this sensor up and running in my home automation setup, and I’m thrilled to say it’s working like a charm!
Understanding the Modes
Before diving into the setup, it’s crucial to understand the different modes the AJ-SR04M can operate in. Here’s a quick breakdown:
- Mode 1 (R19 open): Trigger-based mode where the sensor emits a pulse and measures the time it takes for the echo to return. This mode is great for short-range measurements.
- Mode 2 (R19 with 300k resistor): Similar to Mode 1 but requires a longer trigger pulse to wake up from low power mode. Ideal for battery-powered applications.
- Mode 3 (R19 with 120k resistor): Continuous scanning mode where the sensor sends signals every 120ms and returns the distance as a 16-bit value over UART. This is perfect for constant monitoring.
- Mode 4 (R19 with 47k resistor): Triggered mode where the sensor waits for a serial command (0x01) to start measuring. Great for scenarios where you want to control the sensor remotely.
My Setup
I decided to go with Mode 3 for my setup because I wanted the sensor to continuously monitor a specific area without manual intervention. To achieve this, I soldered a 120k resistor onto R19 and configured my ESP32-C6-Zero accordingly.
Here’s the ESPHome configuration I used:
yaml
uart:
tx_pin: GPIO4
rx_pin: GPIO5
baud_rate: 9600
sensor:
- platform: “jsn_sr04t”
uart_id: uart_1
model: “aj_sr04m”
device_class: distance
This setup ensures that the sensor continuously sends distance readings every 120ms, which is then processed by ESPHome and integrated into my home automation system.
Challenges and Solutions
While the setup was relatively straightforward, I did encounter a few hurdles along the way:
Checksum Errors: Initially, I faced issues with checksum failures in the sensor readings. After some research, I realized that the
model: aj_sr04mparameter was causing discrepancies in how the checksum was calculated. Removing this parameter resolved the issue, and I started receiving accurate readings. -
Filtering Noise: The sensor occasionally picked up false readings due to environmental factors like echoes from nearby objects. To mitigate this, I implemented a simple filter that averages the readings over a short period, ensuring more reliable data.
Power Consumption: In continuous scanning mode, the sensor draws a noticeable amount of power. To address this, I integrated a motion sensor trigger so that the AJ-SR04M only activates when motion is detected, significantly reducing power usage.
Results and Impressions
The results have been nothing short of impressive. The AJ-SR04M provides accurate and consistent distance measurements, making it an invaluable addition to my smart home setup. The ability to integrate it seamlessly with ESPHome has also been a huge plus, as it allows for extensive customization and automation.
One thing I particularly appreciate is how the sensor handles different modes. For instance, switching to Mode 4 for remote triggering was a breeze and added a layer of flexibility to my setup. It’s clear that the AJ-SR04M is a robust and versatile sensor that can adapt to various use cases.
Tips for Others
If you’re considering integrating the AJ-SR04M into your ESPHome setup, here are a few tips to keep in mind:
- Understand the Modes: Take the time to understand each mode and how it fits into your use case. This will save you a lot of troubleshooting time down the line.
- Experiment with Filters: Environmental factors can affect sensor readings, so experimenting with different filtering techniques can help ensure accuracy.
- Optimize Power Usage: If you’re using the sensor in a battery-powered application, consider implementing triggers or scheduling to minimize power consumption.
Integrating the AJ-SR04M with ESPHome has been a rewarding experience. It’s a testament to the flexibility and power of ESPHome, and I can’t recommend it enough for those looking to add advanced sensing capabilities to their smart home setup. With a bit of tinkering and experimentation, you can unlock the full potential of this versatile sensor and take your home automation to the next level!
Happy automating! ![]()
