Integrating Apple TV with Home Assistant: A Smooth Experience
I’ve been exploring ways to integrate my Apple TV with Home Assistant, and I must say, the journey has been both challenging and rewarding. After some research and experimentation, I found a reliable method using Node-RED and the atvremote tool. Here’s a brief overview of how I set it up and how it’s been working for me.First, I installed the pyatv library, which is essential for communicating with Apple TV devices. Following the instructions, I paired my Apple TV with the library using the atvremote pair command. This step was crucial as it allowed Node-RED to interact with my Apple TV’s play states.Next, I configured Node-RED to trigger the automation based on my Onkyo home theater system. Whenever the Onkyo turns on, it starts the Node-RED flow, which in turn monitors the Apple TV’s play state. For my other TV, which isn’t as smart, I used a USB power socket and a reed switch to detect power changes, ensuring the automation starts seamlessly.The Node-RED flow itself is quite straightforward. It captures the play state updates from atvremote and converts them into readable messages for Home Assistant. I set up a trigger to handle rapid-fire commands, preventing any unwanted disruptions in my home theater experience. Finally, I integrated this with my Vizio TV, ensuring it shuts off after 14 minutes of inactivity, which has been a lifesaver, especially with my 4-year-old around.This setup has completely transformed how I interact with my entertainment system. It’s now fully integrated with Home Assistant, allowing me to create rules based on the Apple TV’s play state. For instance, I can dim the lights when a movie starts or pause the music when the TV turns on. The possibilities are endless!If anyone is looking to achieve similar integration, I’d be happy to share my Node-RED flow or provide guidance. It’s a fantastic way to enhance your home entertainment experience without diving into complex setups.
