I’m thrilled to share my successful integration of APSystem solar energy into Home Assistant! This setup allows me to monitor my daily energy production and integrate it seamlessly with my smart home ecosystem. Here’s how I did it, step by step:1. Identify Your ECU: First, determine if your ECU has a web interface. If it does, you can scrape data directly from the browser. If not, PVOutput integration is the way to go.2. Web Interface Setup: For ECUs with a web interface, use the scrape sensor in Home Assistant. Open the ECU’s web page, inspect the elements to find the correct selector, and set up the sensor with the appropriate configuration.3. PVOutput Integration: If your ECU lacks a web interface, register on PVOutput and create a system. Use the aps-to-pvoutput script to feed your solar data into PVOutput, which Home Assistant can then access.4. AppDaemon Setup: Install AppDaemon on your Home Assistant instance. Configure the script to run periodically, ensuring your solar data is always up-to-date.5. Home Assistant Configuration: Add the PVOutput sensor to your Home Assistant setup. Optionally, create a template sensor to display energy production in a user-friendly format.6. Automation and Visualization: Use the integrated data to create automations, such as notifications when energy production peaks, or visualize your solar output in dashboards.This integration not only enhances my smart home but also provides valuable insights into my energy consumption. I hope this guide helps others achieve similar results. Feel free to reach out with questions or suggestions!
