Hey everyone, I’m excited to share my recent project of integrating an Aqara button into my Zigbee2MQTT setup. I’ve been exploring the world of smart home automation for a while now, and this was a fun challenge that I wanted to document for others who might be tackling something similar.
I started by researching the Aqara WXKG20LM button, which I’ve heard great things about. The goal was to set it up with Zigbee2MQTT to control my smart lights and other devices. After some digging, I found that the process involves a few key steps that I wanted to lay out clearly.
First, I needed to ensure that my Zigbee coordinator was properly set up. I’ve been using a Conbee II stick, and I made sure it was correctly configured within my Home Assistant setup. The next step was to reset the Aqara button to factory settings. This was a bit tricky at first, but I discovered that holding down the button for about 10 seconds does the trick.
Once the button was in pairing mode, I used the Zigbee2MQTT interface to add it to my network. This was straightforward, and I was pleasantly surprised at how seamless the process was. The button paired almost instantly, and I could see it listed in my devices within Home Assistant.
The real fun began when I started configuring the button actions. I wanted to create a scene where pressing the button once would toggle my living room lights, and holding it down would adjust the brightness. This required a bit of tinkering with automations in Home Assistant, but the satisfaction of seeing everything work together was worth it.
One thing I learned along the way is the importance of testing each action thoroughly. I initially had some issues with the brightness adjustment not responding correctly, but after reviewing my automation rules, I realized I had missed a small detail in the configuration. Fixing that was a quick process, and it made the whole setup much smoother.
I also wanted to share a tip for anyone else working with Zigbee devices: always check your logs in Home Assistant if something isn’t working as expected. The logs can provide invaluable insights into what’s going on behind the scenes.
Overall, this project has been a fantastic learning experience. It’s amazing how a simple device like a smart button can add so much convenience to daily life. I’m already brainstorming other ways to integrate this button into my smart home setup, like controlling my HVAC system or setting up custom scenes for different times of the day.
If anyone has questions or needs help with their own Aqara button setup, feel free to reach out. I’m happy to share what I’ve learned and help troubleshoot any issues. Happy automating everyone! ![]()
