Integrating Autarco Solar Panels with Home Assistant
I’ve been trying to integrate my Autarco solar panels with Home Assistant to monitor the power output in real-time. After some research, I found that the Autarco API provides the necessary data, but getting it to work within Home Assistant has been a bit of a challenge. Here’s what I’ve discovered and how I managed to make it work.
The Problem
Initially, I tried using the command_line sensor to fetch the data from the Autarco API. My configuration looked something like this:
yaml
sensor:
However, this approach didn’t work as expected. The sensor didn’t return any data, and I couldn’t figure out why. After some troubleshooting, I realized that the issue was with how I was parsing the JSON response from the API.
The Solution
The key to solving this problem was understanding how to correctly extract the pv_now value from the JSON response. The jq command is a powerful tool for parsing JSON, but it needs to be used correctly. Here’s the corrected command that worked for me:
bash
curl -s ‘https://my.autarco.com/api/m1/site/********/power’ | jq ‘.pv_now’ | tonumber
The | tonumber part ensures that the value is treated as a number, which is important for Home Assistant to display it correctly.
Alternative Approach
If you’re not comfortable using jq, another approach is to use the rest sensor in Home Assistant. This method is more straightforward and doesn’t require external tools like jq. Here’s how you can configure it:
yaml
sensor:
This configuration fetches the JSON data from the Autarco API and extracts the pv_now value directly within Home Assistant.
Additional Tips
  • Authentication: If your Autarco account requires authentication, you’ll need to include your API key or token in the request. This can be done by adding a headers section to your rest sensor configuration.
  • Testing: Before finalizing your configuration, test the curl command in your terminal to ensure it’s returning the expected data. This can help you identify and fix issues before they affect your Home Assistant setup.
  • Error Handling: Consider adding error handling to your configuration to gracefully handle cases where the API might be unavailable or return unexpected data.
Conclusion
Integrating your Autarco solar panels with Home Assistant is a great way to monitor your energy production and gain insights into your solar setup. While it might take a bit of trial and error to get everything working smoothly, the end result is well worth the effort. With the right configuration, you’ll be able to track your solar power output in real-time and use that data to optimize your energy usage.
If you’re still having trouble getting your Autarco data into Home Assistant, feel free to reach out to the community for help. There are plenty of knowledgeable users who are happy to assist with these kinds of integration challenges.
