As a passionate user of smart home technology, I’ve always been excited about integrating different devices to create a seamless and efficient home environment. Recently, I decided to enhance my heating control system by combining the Bosch Room Thermostat II with the Sonoff TRVZB valve. This setup promised me both manual control through the thermostat’s rotary knob and the convenience of smart automation via my existing Zigbee network.
After some research, I found that both devices could be integrated using Z2M (Zigbee2MQTT) and Better Thermostat. The Bosch thermostat, with its sleek design and reliable performance, seemed like the perfect addition to my setup. However, the challenge lay in configuring it to work seamlessly with the Sonoff TRVZB, especially in terms of overriding the temperature settings directly from the thermostat.
Through some trial and error, I discovered that the key was to ensure both devices were properly paired and recognized within the Z2M interface. By assigning the correct entity IDs and setting up the necessary automations in Home Assistant, I was able to bridge the gap between the manual control of the thermostat and the smart functionality of the Sonoff valve. This integration not only allows me to adjust the temperature with the rotary knob but also maintains the smart scheduling and remote control features I’ve grown accustomed to.
One thing I particularly appreciate is the Bosch thermostat’s ability to provide real-time temperature feedback, which is crucial for maintaining a consistent and comfortable indoor climate. The fact that it runs on battery power also adds to its convenience, eliminating the need for constant power supply checks.
If you’re considering a similar setup, I’d recommend ensuring all firmware versions are up to date and thoroughly testing each component before full integration. It’s also worth exploring the extensive community resources available on platforms like Simon42 and Zigbee2MQTT for troubleshooting and optimization tips.
Overall, this integration has been a rewarding experience, and I’m eager to explore further enhancements to my smart home setup. If anyone has additional tips or experiences to share, I’d love to hear them!
