I’ve been working on integrating my Bosch smoke detectors (BSD-2) into my OpenHAB 4 setup, and I wanted to share my journey and findings with the community. This might be helpful for others looking to set up similar configurations.
First, I’ll start by acknowledging the complexity of setting up Zigbee devices, especially when they’re critical components like smoke detectors. I’ve found that the Zigbee2MQTT integration in OpenHAB 4 is powerful but requires careful configuration. Here’s what I’ve learned:
Device Discovery: After setting up Zigbee2MQTT, my smoke detectors were recognized and listed in the logs. This was a relief, but the real challenge came in properly configuring them within OpenHAB.
MQTT Thing Configuration: Creating a generic MQTT Thing for each smoke detector was straightforward, but assigning the correct channels was tricky. I had to refer to the Zigbee2MQTT documentation to understand the payload structure and map the channels accordingly.
Group Configuration: One of my goals was to create a group of smoke detectors so that any trigger would set off an action. This required some scripting and rule creation, but it’s definitely achievable.
Testing and Validation: I spent considerable time testing each configuration to ensure that the detectors would trigger the desired actions. It’s crucial to simulate scenarios (like a smoke test) to confirm everything works as expected.
Documentation and Community Support: I found the OpenHAB community forums and documentation invaluable. If you’re stuck, don’t hesitate to reach out. There are plenty of resources and experienced users willing to help.
If anyone has additional tips or has successfully implemented a similar setup, I’d love to hear your experiences! Let’s continue to build and share knowledge to make our smart homes safer and more efficient.
