Integrating Ceiling Fan with RF Remote and Wall Switches in Home Assistant
Hey everyone, I’m diving into the world of home automation and came across a pretty interesting challenge with my bedroom setup. I wanted to share my experience and see if anyone has insights or tips to improve the system further!
Currently, I have a ceiling fan with a lamp, controlled by an RF remote. The remote allows me to toggle the lights, adjust fan speed, and set a timer. However, there are three standard wall switches for the lamp, and here’s where things get tricky. If I switch off the lamp via the wall switch, the remote stops working because the lamp loses power. My goal is to make the wall switches act like the remote, sending RF codes instead of just turning the power on or off. Plus, I want everything integrated seamlessly with Home Assistant!
After some research, I considered replacing the wall switches with ones that have both RF and Z-Wave capabilities. This way, they can send the same RF codes as the remote and communicate with Home Assistant via Z-Wave. The idea is to capture the RF code from the lamp remote and have the switches reproduce it. I’m also thinking about how to set this up in Home Assistant so that the system is fully automated and user-friendly.
I’ve reached out to some forums and communities, and while there are a few ideas floating around, I’m still piecing together the best approach. If anyone has experience with RF integration, Z-Wave setups, or similar projects, I’d love to hear your thoughts! Maybe there’s a more efficient way to achieve this or a component I haven’t considered yet.
It’s been a fun learning process, and I’m excited to see how this project unfolds. Thanks in advance for any advice or suggestions you might have!
