I recently faced a challenge with integrating my door lock sensor and door open sensor into a single entity for Alexa. Initially, I had two separate devices, which made it cumbersome to check the door status. After some research and experimentation, I found a solution using Home Assistant’s automation features. By combining the binary sensor and contact sensor into one ‘door’ entity, I can now ask Alexa, ‘Is the front door open?’ or ‘Is the front door locked?’ and receive accurate responses. This integration has significantly improved my smart home experience, making it more seamless and user-friendly. If anyone else is looking to achieve this, I recommend exploring the automation settings in Home Assistant—it’s a powerful tool for customizing your smart home setup!
