Hi everyone, I’m thrilled to share my journey of integrating EnOcean devices into my OpenHAB setup!
I’ve been exploring the world of smart home automation for a while now, and EnOcean devices have been a fascinating addition to my ecosystem. However, I must admit, getting started wasn’t without its challenges, especially when it comes to extracting the device IDs. Let me walk you through my experience and some tips that might help you on your journey!
I started with my Raspberry Pi 2 running OpenHAB, already managing my Hue lights seamlessly. The next step was to incorporate my EnOcean 300 USB module and the Permundo PSC 234 sensor. The initial hurdle was deciphering the Telegram data to extract the device ID. I stumbled upon EnOceanSpy, which proved to be an invaluable tool. Here’s a snippet of the Telegram I worked with:
plaintext
55 00 0A 07 01 EB A5 00 00 00 09 01 97 2B 0A 00 01 FF FF FF FF 3C 00 C1
After some research and trial and error, I managed to parse this data to identify the device ID. It was a moment of triumph! The key takeaway here is to ensure your EnOcean module is correctly configured and that you’re using the right tools to decode the data.
Now, moving beyond EnOcean, I’ve also been experimenting with FitX gym utilization data. The FitX API provides a wealth of information, and I’ve successfully integrated it into Home Assistant using a RESTful sensor. Here’s a quick example of how I set it up:
yaml
sensor:
- platform: rest
resource: https://mein.fitx.de/nox/public/v1/studios/1561099930/utilization
headers:
x-tenant: fitx
name: FitX Gym Utilization
icon: mdi:weight-lifter
value_template: >-
{% for item in value_json[‘items’] if item.isCurrent %}
{{ item.percentage }}
{% endfor %}
This setup allows me to monitor the gym’s real-time utilization, which has been incredibly useful for planning my workouts. If you’re in the FitX ecosystem, I highly recommend exploring this integration!
Another project I’m excited about is achieving full local control of my Roomba 600 series. While ThinkingSync modules work with their server, relying on third-party services can be unreliable. I’ve been experimenting with direct HTTP commands to control Roomba locally. Here’s a quick example of how I send commands:
plaintext
http://192.168.188.51/command.json?command=clean
This approach bypasses the server dependency and gives me complete control over my Roomba’s operations. It’s a great way to ensure my robot vacuum works seamlessly, even if external services go down.
In closing, I want to emphasize the importance of persistence and thorough research when integrating new devices into your smart home setup. Tools like EnOceanSpy and the FitX API have been game-changers for me, and I hope they can be for you too. If you’re working on similar projects or have tips to share, I’d love to hear from you! Let’s continue to push the boundaries of smart home automation together. ![]()
Cheers,
