I recently had the pleasure of integrating my Fibaro Roller Shutter FGR-221 with a Somfy Glydea 60e WT motor, and I must say, it’s been a fascinating journey! At first, I encountered a bit of a hiccup where the motor would only perform a single rotation when I tried to open or close it through the Vera UI5 dashboard. After reaching out to Fibaro support, they suggested adjusting parameter 10. While I was a bit unsure about how to proceed, I managed to tweak the settings, and now everything works like a charm!
This experience really highlighted the importance of proper configuration and the value of community support. If anyone else is dealing with similar issues, I’d recommend checking the device parameters and reaching out to the manufacturer’s support team. Sometimes, a simple adjustment can make all the difference! On a lighter note, I’ve also been experimenting with setting up automated scenes in my smart home. One thing I’d love to figure out is how to make a scene automatically turn itself off after a certain period. For example, I’d love to set up a cozy reading light that dims after 30 minutes of inactivity. If anyone has tips or tricks for achieving this, please share! ![]()
