Integrating Fibaro Radiator Thermostats with Home Assistant: A Step-by-Step Guide
As a homeowner who loves tinkering with smart home technology, I’ve always been fascinated by the potential of integrating Fibaro radiator thermostats into my Home Assistant setup. However, my journey wasn’t without its bumps, and I wanted to share my experiences and solutions to help others who might be facing similar challenges.
The Challenge
One of the first hurdles I encountered was the inability to use Fibaro radiator thermostats with the default Home Assistant tiles. It turns out that HR can’t simultaneously retrieve the setpoint and temperature readings from the same device, as they originate from different sources. This was a bit of a setback, but I quickly realized that creating separate tiles for each radiator was the way to go.
The Solution
I ended up creating individual tiles for each of my 20 Fibaro radiators. While this was a bit time-consuming, it was worth it for the functionality it provided. The next challenge was getting the heating schedule override feature to work. After some research, I discovered that Fibaro has a specific method for setting overrides, and I managed to replicate this within Home Assistant using custom scripts.
Tips and Tricks
  1. Custom Scripts for Override Schedules: If you’re struggling with override schedules, try using the fibaro.call method within Home Assistant. This allows you to set a specific temperature for a defined duration, which is perfect for temporary adjustments.
  2. Separate Tiles for Each Device: While it might seem tedious, creating individual tiles ensures that each radiator is fully controllable within the Home Assistant interface.
  3. Community Resources: Don’t hesitate to reach out to the Home Assistant community for help. Forums and Discord channels are invaluable for troubleshooting and sharing knowledge.
Conclusion
Integrating Fibaro radiator thermostats with Home Assistant is definitely achievable, and the payoff in terms of convenience and control is immense. By breaking down the problem into manageable steps and leveraging the wealth of resources available, I was able to create a seamless smart home experience. If you’re considering this setup, I highly recommend giving it a try—it’s a game-changer for home comfort!
If anyone has additional tips or遇到的问题, feel free to share them below. Let’s continue to learn and grow together in the smart home community! :rocket:
