Integrating Garmin MyHomeControl with openHAB REST APIs: A Smooth Experience
I recently embarked on a project to integrate my Garmin MyHomeControl app with openHAB using REST APIs via myopenhab.org. Initially, I was a bit overwhelmed by the setup, but I’m thrilled to share that it’s working seamlessly now! Here’s how I tackled it:
  1. Understanding the Basics: I started by reviewing the MyHomeControl documentation. It was crucial to grasp how URLs and JSON bodies are structured. For instance, commands like turning on a light were formatted as 192.168.2.1/sw/23_and_command=on. I learned to replace special characters like & with *and* to prevent saving issues in Garmin Connect.
  2. Authentication Challenges: Setting up basic authentication was a hurdle. After some research, I discovered that encoding credentials directly into the URL wasn’t the only solution. Instead, I utilized the jspost method to send raw text commands, which openHAB could interpret without issues.
  3. Testing and Tweaking: I began with simple commands and gradually added more complex ones. Using tools like Postman helped me verify that my commands were correctly formatted before integrating them into MyHomeControl. This iterative approach saved me a lot of time and frustration.
  4. Real-Life Integration: Now, I can control my smart home devices effortlessly through MyHomeControl. Whether it’s adjusting the lighting in my living room or setting the perfect temperature, everything responds smoothly. This integration has significantly enhanced my daily routine, making my home more connected and user-friendly.
If anyone else is looking to integrate Garmin MyHomeControl with openHAB, I highly recommend starting with simple commands and gradually expanding. Don’t hesitate to reach out if you have questions or need advice—I’m happy to help!
Cheers to a smarter home!
