Hey everyone! I’ve been diving into integrating my new GivEnergy inverter with Home Assistant, and I thought I’d share my journey and some tips along the way. ![]()
First off, I was really excited about the GivEnergy system because it comes with a nice API that can query their cloud services. Plus, there’s this GivTCP service that seems to be a local solution running in a Docker container, providing MQTT and REST access. That’s super handy!
I started by checking out the existing add-on for Home Assistant, but I wanted to get it working seamlessly. Here’s what I did:
Installing GivTCP: I set up a Docker container for GivTCP on my local network. This gave me direct access to the raw data from my inverter without relying solely on the cloud. It was a bit of a learning curve, but the community forums were super helpful!
Configuring Home Assistant: Once GivTCP was up and running, I configured Home Assistant to pull data from it. I used the REST service integration to fetch real-time data like power generation, battery status, and more. It’s been a game-changer for monitoring my solar setup!
Automation Fun: I also set up some automations to notify me when my battery is full or if there’s a drop in power generation. It’s all about staying in the loop without constantly checking the app!
If you’re looking to integrate your GivEnergy inverter, here are a few tips:
- Make sure your Docker setup is stable before diving into GivTCP.
- Test your API calls manually using tools like curl or Postman to ensure everything is working as expected.
- Don’t hesitate to tweak the Home Assistant configuration to match your specific needs!
I’d love to hear how others are integrating their GivEnergy systems or if anyone has tips for optimizing performance. Let’s keep the smart home magic flowing! ![]()
