I recently decided to integrate my Google Home and SmartThings devices into my OpenHAB setup, and I must say, the process has been quite rewarding! ![]()
My Setup and Experience
I’ve been using Zigbee2MQTT for controlling my lamps, and it works perfectly. I added the thing in the frontend and configured channels for color, brightness, and switch. Now, I wanted to make sure my Google Home recognizes my lamps as complete devices. Initially, I faced a challenge where adding metadata to items created multiple entries in the Google Home app. After some research, I figured out that adding metadata at the thing level instead of individual items solved the issue. This made my setup much cleaner and more user-friendly!
SmartThings Integration Journey
Integrating SmartThings was a bit tricky at first. I had to create a SmartApp through the SmartThings Developer site, which wasn’t immediately obvious. Once I got through that, I realized I needed to set up a hub. The mobile app didn’t have an explicit option for this, but I found a workaround by designating a device as the hub. This allowed me to seamlessly integrate my SmartThings devices into OpenHAB. It’s amazing how everything came together once I got past the initial hurdles!
DIY Project: Modifying My Heater
Another exciting project I undertook was modifying my Mill Glass heater to have full local control. I followed a guide to replace the proprietary controller with an ESP8266, enabling me to control it through Home Assistant. This was a fantastic DIY experience, and it’s so satisfying to have a device that works perfectly without relying on external servers. Plus, my wife approves of the energy-saving features! ![]()
Challenges and Learning
Of course, not everything went smoothly. I encountered issues with the AC Coupling Smart Charge feature on my Conext SW4048. It was frustrating to see the feature disable when trying to use battery power. After spending weeks experimenting, I realized that using Node-RED to toggle features based on energy production might be the solution. It’s a bit manual, but it works for now!
Integrating various devices into OpenHAB has been a fantastic learning experience. It’s incredible how these devices can work together to create a seamless smart home environment. I’m excited to continue exploring and improving my setup. If anyone has tips or tricks for optimizing their integrations, I’d love to hear them!
Happy automating! ![]()
