Integrating Google Home, Philips Hue, and SmartThings for Seamless Lighting Control
I’ve been on a journey to create a seamless smart home ecosystem, and I wanted to share my experience and findings with the community. My setup started with Google Home and Philips Hue, which worked beautifully out of the box. However, when I introduced the SmartThings Hub V3, things got a bit more complicated, and I wanted to figure out the best way to integrate everything for optimal control.
The Challenge
Initially, I added the Hue Bridge to my SmartThings configuration so that I could automate lighting based on sensor triggers. However, I noticed that when I linked both the Hue account and SmartThings account to my Google Assistant, all my lights appeared twice. This duplication raised questions about the best approach to control my lights—should I rely solely on Google + Hue or Google + SmartThings?
The Exploration
I experimented with controlling the lights through both Google Home and SmartThings. One concern was whether Hue Scenes would still be accessible if I primarily used Google Assistant. Conversely, if I relied on Google and Hue, would SmartThings still be able to control the lights? It was a bit confusing, but I wanted to find a setup that leveraged the strengths of each platform.
The Solution
After some trial and error, I found that the best approach was to use Google Assistant as the primary interface for daily interactions, while keeping SmartThings for more complex automations. Here’s how I structured it:
  1. Google Assistant for Quick Controls: I kept the Hue integration with Google Assistant for straightforward commands like “Turn on the bedroom lights” or “Set the living room to movie mode.”
  2. SmartThings for Advanced Automations: I used SmartThings to create routines that trigger Hue lights based on sensor inputs, such as turning on hallway lights when the motion sensor detects movement at night.
  3. Hue Scenes for Specific Modes: I ensured that Hue Scenes were still accessible through Google Assistant by creating specific voice commands for them, like “Activate reading mode.”
The Outcome
This setup allows me to enjoy the simplicity of Google Assistant for everyday use while still benefiting from SmartThings’ powerful automation capabilities. The Hue lights remain fully integrated, and I haven’t encountered any issues with Scenes or automations.
Tips for Others
  • Avoid Duplicate Devices: Make sure your devices are only linked once to prevent duplication in your Google Assistant.
  • Leverage Each Platform’s Strengths: Use Google for quick, voice-controlled interactions and SmartThings for more complex automations.
  • Test Scenes and Automations: Before finalizing, test all your Scenes and automations to ensure they work as expected.
I hope this experience helps others who are looking to integrate multiple platforms into their smart home setup. It’s all about finding the right balance and configuration that works best for your lifestyle!
Cheers,
Dave
