Hi everyone! I wanted to share my experience with integrating Govee and Philips Wiz lights in my home. While both brands are fantastic on their own, I was curious to see if I could create a unified lighting system that combines the best of both worlds. ![]()
After some research and experimentation, I found that using IFTTT and Home Assistant was the key to bridging the gap between these two ecosystems. For example, I set up a routine where turning on a Govee light also triggers a Philips Wiz light in the same room. It’s like having a symphony of lights that work together seamlessly! ![]()
One challenge I faced was ensuring consistent brightness levels across different devices. I solved this by calibrating each light individually and grouping them in Home Assistant. Now, I can control multiple lights with a single command, whether it’s through voice commands or the Home Assistant app. ![]()
I’d love to hear from others who have successfully integrated multiple lighting brands. What tips or tricks have you discovered? Let’s continue to push the boundaries of smart home automation together! ![]()
