Integrating Govee Appliances with Home Assistant: A Smooth Experience
Hello everyone, I wanted to share my recent experience integrating a Govee appliance into my Home Assistant setup. After spending some time researching and experimenting, I can confidently say that it was a seamless process!
I recently acquired the Govee H7140 air humidifier and was eager to control it through Home Assistant. Initially, I was a bit unsure about how to proceed, but the Govee API made everything much simpler. By using the REST command integration in Home Assistant, I was able to send on/off commands and adjust settings directly from my dashboard.
Here’s a quick rundown of what worked for me:
  • API Integration: I set up a REST command service in my configuration.yaml file, which allowed me to send HTTP POST requests to the Govee API. This was straightforward and didn’t require any additional hardware.
  • Device Control: Using the API, I can now toggle the humidifier on and off, adjust the mist level, and even switch between different operating modes. It’s incredibly satisfying to have this level of control from my phone or the web interface.
  • Automation Possibilities: The best part is the automation potential. I’m already planning to create routines that turn the humidifier on during specific times or when certain conditions are met (like low humidity levels).
I’d love to hear from others who have integrated Govee devices into their smart home setups. What tips or tricks have you discovered? Are there any features you’d like to see added to the Govee API? Let’s share our experiences and help each other make the most of these devices!
Cheers,
