Integrating Govee LED Strips with Homey: A Smooth Experience
After setting up my new kitchen, I decided to enhance the lighting with Govee CCT (WW+CW) LED strips. The goal was to integrate them seamlessly into my Homey ecosystem for a smart and customizable lighting solution. Here’s how I made it work!
The Setup
I wanted a system that was both versatile and easy to control. My requirements were:
  • One zone for multiple strips: I have three strips in total, and I wanted them to function as a single unit.
  • Remote control: While not essential, having a remote option adds convenience.
  • Physical wall button: I opted for a Gira pulse-button, similar to what I use with my Fibaro Dimmer 2’s.
  • Zigbee or Z-Wave connection: Compatibility with Homey was crucial.
Solution Found
After some research, I found an AliExpress solution that fit the bill: a WW/CW LED controller with 2.4G wireless functionality. It supports 12V, 24V, and 36V, which was perfect for my setup. The controller also allowed me to manage two channels independently, giving me more flexibility in how I set up the strips.
Installation and Integration
The installation was straightforward. I connected the strips to the controller and paired the controller with Homey. The setup within Homey was seamless, and I was able to create custom scenes for different lighting moods.
Tips for Others
  1. Check Compatibility: Ensure that your controller supports the voltage of your LED strips.
  2. Test Before Full Installation: If possible, test the controller with one strip before connecting all of them.
  3. Use Quality Cables: Invest in good quality cables to avoid any voltage drop issues.
  4. Scene Programming: Take advantage of Homey’s scene programming to create different lighting scenarios for various times of the day or occasions.
Integrating Govee LED strips with Homey has been a fantastic experience. The CCT feature allows for a wide range of lighting temperatures, making it suitable for any setting. Whether it’s a cozy evening or a bright daytime, the strips adapt perfectly. The ability to control everything through Homey adds a layer of convenience that I truly appreciate.
If you’re considering a similar setup, I highly recommend exploring Govee’s LED strips and compatible controllers. The combination of quality hardware and smart home integration makes it a winning solution!
Happy smart home DIY’ing! :rocket:
