I recently stumbled upon an exciting project called Cassa HA, and I wanted to share my enthusiasm with the community! This innovative solution allows you to transform your Homey Pro into a dedicated Home Assistant device. If you’ve ever wanted to merge the robust hardware of Homey with the extensive ecosystem of Home Assistant, this is the perfect bridge!### What is Cassa HA?Cassa HA is a tool designed to modify a Homey Pro backup file, enabling it to boot directly into Home Assistant instead of the default Homey OS. The process is straightforward:1. Backup your Homey Pro (you’ll get a .homeyprobackup file).2. Use Cassa HA to modify this backup file.3. Restore the modified backup to your Homey Pro.The result? A Homey Pro that runs Home Assistant exclusively, without any Homey services hogging resources!### Why Should You Care?- Best of Both Worlds: Leverage Homey’s solid hardware and radios while benefiting from Home Assistant’s vast community, add-ons, and flexibility.- Simplicity: No need for additional hardware—everything runs smoothly on your existing Homey Pro.- No Proprietary Files: The tool works directly on your backup file, ensuring no redistribution of proprietary software.- Rollback Option: Always have the ability to restore a stock backup if needed.### The Coprocessor Bridge Add-OnThe developer is also working on a Homey Coprocessor bridge add-on for Home Assistant. This add-on aims to integrate Z-Wave and LED functionalities seamlessly. While still in early development, it’s a promising step toward full integration, especially considering Zigbee is already natively supported.### How to Get Started1. Check out the official GitHub repository: Cassa HA.2. Follow the detailed instructions in the README to modify your backup file.3. Restore the modified backup to your Homey Pro and watch as it boots into Home Assistant!### A Call to the CommunityThis project is still evolving, and the developer welcomes feedback and contributions. If you’ve tried Cassa HA or have suggestions for improvement, please share your experiences in the comments below or on the GitHub page.If you’re passionate about smart home integration and love the idea of combining two powerful ecosystems, I highly recommend giving Cassa HA a try! It’s a fantastic way to enhance your smart home setup without the hassle of additional hardware.Let’s discuss your thoughts and experiences with this innovative solution below! ![]()
