I’ve been a long-time user of Kankun/Konke WiFi plugs, and I must say, they’ve been a reliable addition to my smart home setup. Initially, I was using them with SmartThings thanks to the device code provided by Krys Allen. However, my journey took a new turn when I decided to migrate my entire ecosystem to Hubitat.
At first, I was a bit concerned about compatibility, but I quickly realized that with a bit of tinkering, these plugs could integrate seamlessly. I was able to turn them on and off using some simple HTML scripts and even retrieve their status. The real challenge was making them work within Hubitat’s ecosystem.
After some research, I discovered that these plugs run on OpenWRT, which allows SSH access. This was a game-changer! I could directly control them via SSH, which not only enhanced their functionality but also gave me more control over their operations.
One thing I noticed is that these plugs were sold under various brands like JTD, Amcrest, and Quisc. While the original app wasn’t the most user-friendly, the underlying hardware was solid. I was able to create custom scripts to handle their integration, which made the whole process much smoother.
If you’re looking to integrate these plugs into your Hubitat setup, here’s a tip: take advantage of their OpenWRT capabilities. You can write simple scripts to handle their on/off states and even monitor their usage. This level of customization really elevates their utility.
Overall, my experience has been quite positive. These plugs are versatile, reliable, and with a bit of technical know-how, they can fit perfectly into any smart home setup. I’m excited to see how the community continues to innovate around these devices!
