Integrating legacy devices into a modern smart home system can be both rewarding and challenging. I recently faced this challenge when trying to incorporate my old FS20 heating control system with HomeMatic, a more advanced smart home platform. The journey taught me a lot about compatibility, creativity, and the importance of community support.
The Challenge
Our heating system has been running on the FS20 system for years, using HMS100T temperature sensors to monitor floor and wall heating. However, as more sensors began to fail, we realized the need to upgrade. Unfortunately, HomeMatic doesn’t offer cable-based temperature sensors in the same configuration. The question was: Could we repurpose the existing HMS sensors or find a reliable alternative?
The Solution
After some research, I discovered that while direct conversion of HMS sensors to HomeMatic wasn’t feasible, there were workarounds. Z-Wave compatibility became a game-changer. By integrating Zooz Zen 27 switches, we bridged the gap between legacy and modern systems. These switches not only supported the necessary profiles but also allowed for seamless integration with our Home Assistant setup.
Lessons Learned
- Compatibility is Key: Always check if your legacy devices can be integrated using bridges or adapters. Z-Wave and Zigbee are great intermediaries.
- Community Support: Forums and communities are invaluable. Tips from others who’ve faced similar challenges can save you hours of trial and error.
- Backup and Testing: Before making any changes, ensure you have backups. Testing in a controlled environment can prevent system-wide issues.
A Tip for Others
If you’re looking to integrate older systems, start small. Test one device at a time to identify any potential issues. Documenting each step can also help troubleshoot problems later.
This experience reinforced how a smart home can evolve without discarding everything. With the right approach, legacy systems can coexist with modern technology, creating a truly integrated smart ecosystem.
Happy integrating! ![]()
