Hey everyone, I wanted to share my exciting journey of integrating my Lelit MaraX coffee machine with Home Assistant. This project has been a mix of curiosity, learning, and a bit of trial and error, but the outcome has been truly rewarding!
I stumbled upon an amazing Reddit article that inspired me to connect my coffee machine to Home Assistant. The idea was to monitor and control the machine’s temperature and brewing status directly from my dashboard. I decided to use an ESP32 module for this project because of its built-in OLED display and compatibility with ESPHome.
The process involved a few steps. First, I had to extract data from the coffee machine’s PID controller. The machine sends temperature and status data multiple times a second, which I needed to parse and send to Home Assistant. I used a Wemos Lolin32 board for this task, connecting it via UART to the coffee machine’s PID. The data includes the current and target steam temperatures, heat exchanger temperature, and brewing status.
Once the data was being received, I faced the challenge of displaying it both on the ESP32’s OLED screen and within Home Assistant. I set up the ESP32 to show the current temperature when data was received and switch to a clock display if no data was received for 5 seconds. This added a nice touch of functionality to my morning routine.
In Home Assistant, I created dashboards to visualize the coffee machine’s performance. This allows me to monitor brewing cycles, track temperature trends, and even set custom alerts if the machine overheats or runs low on water. The integration has made my coffee brewing process more efficient and enjoyable.
I also faced some challenges along the way. For instance, ensuring stable communication between the ESP32 and the coffee machine’s PID was tricky. I had to tweak the UART settings and experiment with different cables to get a reliable connection. Thankfully, the ESPHome community was very supportive, and I found helpful resources and tutorials that guided me through these hurdles.
One thing I’m particularly proud of is the custom case I designed for the ESP32. It not only protects the module but also blends seamlessly with my kitchen’s aesthetic. I used a 3D printed enclosure that I found on Thingiverse, which provided the perfect fit and a professional look.
This project has been a fantastic way to combine my love for coffee with my interest in home automation. It’s also been a great learning experience, teaching me more about ESPHome, data parsing, and integrating custom devices into Home Assistant. I’m now looking forward to exploring more automation possibilities, maybe even setting up a routine that starts brewing my morning coffee as I approach home!
If anyone has similar projects or tips for integrating kitchen appliances, I’d love to hear about them. Let’s continue to innovate and make our homes smarter and more convenient!
