Integrating Logitech Harmony Companion Buttons into OpenHAB 1
I recently acquired a Logitech Harmony Companion and am excited to integrate its additional Home Automation buttons into my OpenHAB setup. I’ve been reading about the Philips Hue Emulator (also known as the Amazon Echo Binding), which seems like a promising solution for this task. However, I’ve noticed that this emulator is only compatible with OpenHAB 2, and I’m currently running OpenHAB 1. This has left me wondering if there’s a way to utilize this functionality within my existing setup.
I’ve explored various forums and documentation to see if anyone has successfully implemented a Hue emulator or a similar workaround in OpenHAB 1. While there are some discussions about the challenges of backward compatibility, I’m hopeful that there might be a creative solution or alternative approach that I haven’t discovered yet.
If anyone has experience with integrating third-party devices into OpenHAB 1 or knows of any workarounds for emulating Hue devices, I’d greatly appreciate your insights. Whether it’s a different binding, a custom rule, or even a hardware-based solution, I’m open to suggestions. My goal is to seamlessly integrate these buttons to control my two bulbs, roller shutter up/down functions, and two plugs, just as I would with a Hue setup.
Thank you in advance for any guidance or advice you can provide. I’m eager to find a solution that allows me to enhance my smart home setup without upgrading my OpenHAB installation just yet.
