Hey everyone, I wanted to share a project I’ve been working on to integrate my Logitech Harmony remote with my home automation setup. It’s been a fun challenge and I hope others might find it useful too!
I recently discovered a Node.js script that converts Harmony remote .conf files into JSON format. This has been super helpful for me since I’m using this JSON data to create a dropdown menu in the HA frontend. The process is pretty straightforward:
- Download the script: You can find it on GitHub here.
- Place the script: Put it in the same folder as your Harmony config files.
- Install dependencies: Run
$ npm i -g lodashon a machine with Node.js v8+ installed. - Run the script: Execute
node harmony_config_parser.js [your_config_filename.conf].
This will generate a JSON file in the same directory, which I then use to populate the dropdown menu. It’s been a great way to streamline my remote control setup!
I’d love to hear if anyone else has tried something similar or has tips for improving this integration. Happy automating! ![]()
