Integrating Lumary Smart Lights with Shelly Switch
Hey everyone, I’m really excited to share my experience with integrating Lumary smart can lights into my kitchen setup. I’ve been using Home Assistant with the Local Tuya integration, and so far, everything has been working smoothly. However, I’ve encountered a challenge that I’m hoping the community can help me with.
I wanted to control these smart lights using a traditional wall switch while still maintaining their smart functionality. To achieve this, I decided to use a Shelly 1L as a detached switch. The idea was to program automations so that flipping the switch would trigger specific actions, like turning the lights on or off, or even setting them to night light mode when it gets dark.
At first, this setup worked perfectly. I could automate the lights to turn on at sunset and adjust their brightness based on occupancy sensors. However, after about a week, I noticed that the Shelly 1L would occasionally go offline. This meant that my automations wouldn’t trigger, and I’d have to manually reset the breaker to get everything working again.
I’m not entirely sure what’s causing this issue. Is it a problem with the Shelly itself, or could it be related to my wiring? I’ve never used a Shelly with a neutral wire before, so I’m wondering if that’s a factor. I’ve heard that some devices require a neutral connection to function properly, especially when dealing with automation and constant power.
I’m really curious to know if anyone else has faced a similar issue or has a more elegant solution for controlling smart bulbs with a wall switch. Maybe there’s a different device or configuration that could make this setup more reliable. I’d love to hear your thoughts and experiences!
On a positive note, I’m thrilled with how the Lumary lights have transformed my kitchen. The ability to adjust their brightness and color has made a huge difference in the ambiance of the room. It’s just a matter of ironing out this Shelly issue, and I’ll be all set!
Thanks in advance for your help and insights!
